The Frog Lube trial.
Mar 8, 2008
237
8
Alabama
Any ya'all use the new Frog Lube on your guns? Man ya gotta try this stuff. Your actions will slide like silk, and your guns are not oily. No more lint and dust sticking to your moving parts. It actually "seasons" the metal. Google "FrogLube" and check it out. Hey, if the Navy Seals use it, it must work!! jimsjinx
Interesting.
I'm looking at the site now. Haven't cleaned my guns in quite awhile. (They've actually turned into a collection, if you know what I mean). This just might do the trick for the next cleaning which is long over-do. Thanks for sharing. ThumbUp
Hey Jim I have used for a while now, dont know if you do, but I put it in my clips also_One of my guns is a cheap 9 mm ,that now I can fire as quick as I want without jamming.Never buy a cheap semi automatic .
I love the stuff! On the cheap semi auto... give it a while if it is new. Stuff will wear in after time at the range. Although, any gunsmith cringes at the thought of "wearing in", it's the truth with the more economical pistols/rifles. Every part is hand fitted and honed by hand in the higher end weapons, and that's how it SHOULD be. But unfortunately, the cheaper stuff is only de-burred and assembled. I'v seen some cheap guns made sweet by the right guy. Trouble is, your local gunsmiths are usually a tad flaky and opinionated. So it's hard to find someone who isn't a "hack". Anyway, I think every gun I own is gonna get seasoned with Frog Lube. It just works!!! Take care, Jim (jimsjinx)
Hey Jim thanks....the reason,I honestly put in back in case until lubing, and still dont trust it not to jam, but maybe I could use it a little more and let it wear.I guess I better not name brand bought it at a Birmingham show liked the way it feels but was very pissed ............. [////// point ].
Have to pick up some of this stuff. Been using an old bottle of Lucas Gun Lube I found of my Granddad's when cleaning out the old garage. No telling how old it is and definitely Awesome stuff but just about empty. Pretty sure they don't make it anymore so been looking for an acceptable replacement. Sounds like this Frog Lube should do the trick. Thanks.
They still make the Lucas http://www.jegs.com/i/Lucas+Oil/639...&cagpspn=pla&gclid=CK-gitzUxboCFQyg4AodszQA0A
Thanks for the Find Mike. Sticking with the Lucas then. Nothing against any other but that Stuff is awesome and Creatures of Habit ya know.
wzejda
