You're on the right track by thinking of a mockup. Make it out of wood and take careful measurements. I know I had to redo mine after the first build. I ended making it longer. Now it is long with a homebuilt leading link front end. Good luck on the build and post photos. We all like pictures.
Look in the phone book and maybe you can find some places that build race cars and they can get some tubing for you that they use to build roll cages, maybe they will even bend it for you, heck, maybe they will even weld it for you. How much do you want to spend?
Something I did that helped a ton! My "upright" tube; the one that comes up to the triple tree neck is a 2" x 3" rectangular tube. What was done with that before welding the neck on for the bearings is it was filled with cement!
Talk about adding some front end weight.
Granted, I am running a 1935cc with dual 44 Webers, and it will still pick the front end off the ground, but it is a boat load more stable than just having a hollow tube. It actually seems to get more stable the faster the scooter goes. LOL. It seems better at 80 than at 40.
I will get some pictures of the trike in the next few days and post one that shows the front "upright" tube.
And as you mentioned, I have the front seat pretty far forward to also help in keeping the front end down.
