Tank Lift Kits
Do they really help with wind coming up over the tank? What size? Thanks. Willie
The Tank Lift will help with the wind coming over the tank. You also be able to see your rocker covers, with out a Tank Lift all the chrome is hidden. You would need to check for clearance to see what size you will need.
This is how you can check for clearance.
1. With bike on kickstand, take the bolt out of the front of your tank.
2. Loosen (do not remove) the bolt at the rear of your tank.
3. Turn your handlebars all the way to the left and raise the tank up your desired lift height to check for clearance issues.
4. Turn your handlebars all the way to the right and raise the tank up your desired lift height to check for clearance issues.
Also, here is a thread on DK Custom Tank Lifts, information thread.
http://www.triketalk.com/forum/threads/18555-Dk-custom-tank-lifts-information-thread
Kelsey
Roger71!!
