Members experience with Superbrace on GL1500 SE 1995 w/Hannigan conversion. Thanks......
orag:
Hocky
Whey you get your "Super Brace", could you measure the ID of the clamps. I'm Looking to see if I can make something work on my Kawasaki.
Ray, Close as I can measure is 5-17/32" between the forks. The brace for the 1500 Gold Wing doesn't use clamps, it's open ended & bolts on. [h=3]SuperBrace | Honda Goldwing 1500[/h]Hope that helps.
Hocky
Be sure and follow instructions for Superbrace on the 1500.Some require a slight trimming to set in so as not to bind the front shocks.After a couple hundred miles re-check torque and you are good to go.
You will like the difference.
Sonny, You were right. Lucky I had a file & sand paper handy & I'm glad the S/Brace is made of soft aluminum. It's raining so I've put off my test ride. I'll post the results I find. Next project is a volt meter!
Thanks again………… Hockyorag:
