STATOR HARNESS GROMMET LEAKING
Apr 16, 2025
91
132
Florida
DOUBLETAP
Thinking of spraying some brake cleaner fluid on the grommet and case so i can apply some rtv.
Anyone see a problem with using the brake cleaner on the grommet? Won't take much.
Tired of the minute bit of oil leaking and coating the unders.
Yes, … pull it out a little to expose that area and give a good clean with carb clean (or brake clean) and get it completely oil free.
Then swipe around the entire circumference of that grommet with Black RTV and let it sit overnight.
It’s a quick fix that should last you quite a while. 👍🏻
Trike down
