Star tron fuel additive
Status
Not open for further replies.
Aug 8, 2012
1,345
104
Dora, AL
Rick
:Shrug:...My boat dealer tells me this is the best thing on the market to prevent E10 from causing problems . Has anyone used this product it has some great reviews ? ....:Shrug:
Hey Rick. I've used Startron for about two years now. Don't use it in every tank but do on a very regular basis. My son was having problems getting his truck to pass EPA test and the mechanic told him about Startron.
I did a 20 fill up eval (10 without and 10 with) and found the increased gas mileage just about offset the cost of the Startron. I note a bit more pep with the additive in. I understand there is some octane booster in there.
Here is West Texas we don't have to worry about moisture much but the E10 gas is not the best for our bikes so if we can counter that at a reasonable cost then I'm all for it...
ThumbUp...What you said is basically what all the reviews I read said . I think I'm about to order some , and if you think about it that's a small price to pay for the protection .
There are very few places here you can get gas without E10 . Makes the tree huggers and corn farmers grinn though .:Shrug:
I'm only on my first bottle and it seems to be helping but couldn't say for sure, yet. The best endorsement for it was from the "usually reliable source" who put me on to it. He swears by it. Around here, seems to be about $8 per bottle. If you know/find a less expensive source, be sure to let us know.
I use Startron all the time. I started using it when ol'man told me about it at the last rally. It has helped on gas mileage and just seems to run better. I will continue to use it.
With Rod as my new, additional, "usually reliable source", I am becoming a believer, quicker... :D :laugh: ThumbUp
No 8.95 at the local Autozone called , may be cheaper at WalMart boat section but I'll just go to Autozone ..!! ThumbUp Thanks Guys ,,,now I know it can't be all bad ....:Coffee:
Do you guys go by the directions and only use 1 ounce to 16 gallons ,, I'm one of those who thinks if one is good two is twice as good .
I will be picking up a bottle tomorrow ,rained all day today !!!!....:Shrug:
Unless they changed the formula that is on ounce treats 6 gallons of gas. At least that is what is printed on my bottles. I bought a couple cases last year so maybe times have changed?????
Never saw the need to increase the dose....
:Shrug: ...Well that will work out just right trike has 10 gallons 2 ounces ,,, the boat has 50 gallon there goes that 8 ounces !!!!!;)
Star Tron mixing ratio's... I just found out there are (3) Star Tron formulas each with a different mixing ratio. Rather than going thru the "whole thing", instead go HERE and get it straight from the "horses mouth" (and all on a single web page). :)
ThumbUp.....THANKS..... doesn't get much simpler than that .....:D
THANKS !!!!! That is good to know... I'll keep an eye open for the "standard formula" now...
I use it, but haven't really noticed any mileage increase. Just trying to keep the e-10 balanced out. I get mine at Lowes for $7.00 minus the 10% military discount.
Tomg
Star Tron update. I just returned from "Lowes Home Improvement" (was there for another reason). While there, I checked on the Star Tron they sell. It's apparently the "Small Engine Formula" (see HERE) as it'a an 8oz bottle and mixes 1oz to 6 gal gas. The price was $6.97 (same as reported by others) + tax. Using 7% tax, that's $7.46/48 gal (1oz to 6 gals) or $.1554 per gal of fuel treated.
Other than the mixing ratio directions (and I assume concentration of the liquid), I have no idea what's different about the "Small Engine Formula" and the "Standard Formula" (1oz to 16 gals). Of course, keep in mind what "assuming" does. :D
So far, I have found an eBay seller that sells a quart of the "1 to 16" ratio product for $29.99 (free s/h, no tax) The quart will treat 512 gal of fuel (32oz x 16 to 1 ratio) making the cost $.0586 per gal of fuel treated.
Your choice - (round numbers) 6 cents or 16 cents per "fuel gallon" to treat your fuel.
:xzqxz: :xzqxz: .......WOAHHHHHHH GUYS .....It's a good thing there's no hair to be pulling out or I would be bald again !!!!! do I buy the standard or small engine ? :Shrug: :Shrug:
ThumbUpThumbUpThumbUp ......Now that's what I'm talking about !!!!!!
:gah::gah::gah::gah::gah::gah::gah::gah::gah::gah:
At the risk of "beating this to death", but just to be sure if there is any difference between "Small Engine Formula" and "Standard Formula" (other than the concentration/usage ratio or package size), I have emailed them asking for clarification. If/when they answer, I'll be sure to share... Otherwise - Amen, done, auf wiedersehen, goodbye, farewell, adieu. (on this subject). :D :wave4:
Status
JazzInTN
