Stallion trailer hitch
The Stallion comes from the factory with a hitch & wiring. If yours is missing, then somebody removed it. All you need is a vertical hitch, the receiver is welded to the frame.
Let me verify that. I need the receiver.
I think some are miss informed , the stallion does come with a hitch from the factory but unless they changed it on the later models ,its a hitch where as a ball can be mounted , receiver's on the other hand use what is called a draw bar a square tube on some bikes and vechices it mav be mounted vertical or horizanl and uses a square plug with mount hole for a ball . small cars and vans use a 1 1/4 inch square draw bar or flat stock , truck most with a towing package will have a 2 inch draw bar ,,
Cline
