SEE THROUGH BRAZ® NEW PRODUCT!! - Attach HD Saddle Bags without drilling holes!
Jan 21, 2014
230
48
Illinois
Trike Saddle Bag Kit
SEE THROUGH BRAZ [SUP]®[/SUP] introduces a new process for attaching HD trike bags without drilling holes. We use our protective coating and a fastener system that can withstand heat and cold and is designed to hold up to 120 lbs. If the you no longer want the bags on, removal is easy and does not damage paint.
WHY DRILL HOLES TO INSTALL SADDLE BAGS?
You don’t want to drill holes in their $35,000 trike! Give them a solution!! SEE THROUGH BRAZ [SUP]®[/SUP] has designed a kit to install these saddle bags without drilling holes, and will protect the paint underneath. Once installed, the bags can be removed, adjusted or stored as needed.
Location of bags is convenient for both rider and passenger without eliminating the comfort for the passenger. In addition, once they are installed, you are able to change seats without interference. Just remove the bag and readjust without any damage to paint.
Easy as 1, 2, 3 and it is done. This product has been load and weight tested for durability.
The kit includes SEE THROUGH BRAZ protective covering and industrial strength velcro (not the typical kind you can buy at the store). To apply you put on the protective covering on the trike, then apply the industrial strength velcro to the covering. The industrial strength velcro is never put directly on the paint. When the velcro is no longer wanted you just easily remove the protective covering and it removes the industrial velcro with no problems!
Re: SEE THROUGH BRAZ® NEW PRODUCT!! - Attach HD Saddle Bags without drilling holes!
How does this actually work, can you post the instructions?
Stumpe
First you have to apply our SEE THROUGH BRAZ clear material to your trike.
1) Make sure bike is clean
2) Wet hands, film, and bike.
3) Apply film and move into position
4) Smooth out any air bubbles with squeegee
5) Dry area with towel
6) Wait 24 hours and squeegee around edges to make sure it is sealed
Then you apply the Industrial strength Velcro (not the typical kind you find in a store). And then you are apply your saddle bags. Then when you no longer want the saddle bags on anymore (such as you trading in your trike) you just remove the SEE THROUGH BRAZ material. Al will be at the Trike Talk Rally in Eureka Springs and has this product installed on his Trike and he would be happy to show it to you. Please let me know if you have any other questions!
Stumpe
Thank You
Stumpe
Dieseluladstron
