No need to take the passenger backrest off.
Just pull the little passenger pad on the seat forward, push seat back off front clip and lift up. You will have trouble getting the bolts back in. I have new ones from WingStuff with tapered points on them. The stock ones have a blunt end on them and be sure you don't cross tread them. One way is to stick a phillipshead screw drive in one hole to line up that side. then insert the other bolt.
Send for those bolts and you don't need the screwdriver any more.
They set in the holes first try, money well spent !!
Believe me, it's a piece of cake with those tapered bolts ThumbUp
