Replace reflector on back of FW with stop/light
With the forums help, I installed the floor board extenders, DK heat shields, shock lift kit, DK grips, and foot brake extender. Pics to follow.
Now just one more thing. Has anyone replaced the reflector at the rear of the bike with a third brake light? Would like to replace it with a quick flashing light like I had on my other bikes. Thought I would ask the experts before I experiment.
Thanks in advance.
Someone posted here or the "other" trike board about putting a strip of red LEDs under the trunk. When he put his breaks on it illuminated the rear of his trike and the ground. Frankly it looked great. Post is here somewhere
Thanks in advance.
Good to see your list of mods! :)
Below is a different look for the back of the Freewheeler, utilizing the Stealth LED Run-Brake-Turn Lights.
If you want to keep your stock tail lights, then you can use just one of those RBT lights and mount it at the rear center, along with the Strobe Module to get your fast flash when first putting on the brakes.
HLG
