Problems already
:mad:2014 tri-glide-My reverse has stopped working, brought it to dealer-service and they are ordering a new motor. That's fine but now another problem and the dealer is closed for the day. Came home shut the bike down and the flashers started blinking and have not stopped. I have tried holding both blinkers down together, no luck. One at a time, still no go. What can I do? They will not stop
:mad:2014tri-glide-My reverse has stopped working, brought it to dealer-service and they are ordering a new motor. That's fine but now another problem and the dealer is closed for the day. Came home shut the bike down and the flashers started blinking and have not stopped. I have tried holding both blinkers down together, no luck. One at a time, still no go. What can I do? They will not stop
Disconnect battery. Will work,
might fix it.
Do you have the POD Close to the Trike or did you leave it with the dealer..??
With out the POD close by any movement of the Trike will cause the flashers to blink..
Press Both turn signals on at the same time and Decode your Security System. It tells you how in your manual......:Coffee:
Trike down
