Performance Machine Stage 1 install experience
May 8, 2011
755
25
Peru, IN
Leon
stage 1 (new version) - now includes a bolt -on option for the rt. caliper, so you keep the emer. brake, and rear brake line dist. block bolts onto the existing stud with no problem. also remember to remove the rear rear screw on the master cylinder befor installing it. (you only get 1/8 turn out of the allen wrench when you tighten up the rear screw. also adjusnt the pushrod adjusting nut on the rear master cylinder so you get to port open when you release the pedal. then bleeding is quicker. . older versions. local shop just installed a new version on a '11 t/g. and p/m fixed previous problems.
Re: pePerformance machine stage 1 install experience
I'll find out sometime in the future, I have a PM stage 1 kit sitting in the back room right now. I didn't notice anything on the calipers that would allow the usage of the parking brake, but then their stuff doesn't come with instructions enclosed you have to download them. My box shows a 2/1/2012 date on the part number label, just looked inside and don't see anything for a parking brake option and the directions I printed yesterday didn't have anything about them. They must just have recently added this option.
dhinzman1
