Over heating 2009 Tri-Glide
Jul 5, 2011
4
Baltimore, MD
This is POPTOP from Baltimore. Earlier I posted an issue about my trike running hot, and said I would report back if HD found anything. What the problem ending up being was the compression release was sticking open and causing an air leak which threw the computer and everything off. They ended up replacing just about everything from the crank on up, to include the cams due to the overheating.It did a lot of damage. My advise to anyone who has the problem, before you do your own home remedy, is contact Harley and get a case number, because if people don't report the problem, Harley won't know about it, and can't fix the problem.
POPTOP
dyno56ca
