Off the table and more problems to be addressed Shovel head Blues
Aug 16, 2015
349
218
Ft Worth, TX
Bogey
Switched a 4spd of 35yrs not shifting right, and installed a sputhe 5spd and its not shifting like i want, new Rivera clutch $500 bucks.:mad:
Was no fun switching trannys, work intensive. Rode it a bit and it seemed to do better, shifted a bit better but hard to shift, and the clutch seems to be releasing, its a shovel with a sealed primary. :mad:
Front tire had 12lbs, took it to 43lbs now head shake low speed, i brought the rake back in on it, it has adjustable rake aftermarket trees. GRRRRRR. :mad:
Back on the table the rear chain is tight, mmm, maybe that contributes to the problem, we shall see, any suggestions. ? :confused:
Good luck to you, I would not have the patience or the expertise. I know my limitations.
Thanks for the luck. I built this from 75 to 77 soooo Ive had patience that has run out a time tor two. Now instead of being mad, im disappointed, i don't mind working on stuff, but i like a happy ending, no pun intended, wink, wink. Best to ya.
You want patience, try pulling all that plastic off that wing to service it, you will find your bottom i bet. :cool:
Coach Buddha
