Newby here needing some help
May 31, 2023
7
15
Shingletown, CA
Carl
I just purchased a 1994 Goldwing with a csc trike kit. I believe it was converted in 1995 when it was first sold. If so I believe the model would be a Tour. The brake lights are not working and I don't see any way to remove the cover from the outside and I'm thinking I will have to pull the wheels to get to the lights.
The 4 ways and tail lights are working. The fuse is good to the brake light circuit Neither the hand or foot brake will activate the brake lights. Any help would be greatly appreciated. I have emailed CSC about the problem but have not heard back from them yet.
Thanks in advance for any help or suggestions.
Carl (Gringo39)
I just purchased a 1994 Goldwing with a csc trike kit. I believe it was converted in 1995 when it was first sold. If so I believe the model would a Tour. The brake lights are not working and I don't see any way to remove the cover from the outside and I'm thinking I will have to pull the wheels to get to the lights. The 4 ways and tail lights are working. The fuse is good to the brake light circuit Neither the hand or foot brake will activate the brake lights. Any help would be greatly appreciated. I have emailed CSC about the problem but have not heard back from them yet.
Carl (Gringo39)
if your 4-ways are working then its not the lights. my suggestion is get a wiring schematics and start with the bikes circuit. tail lights have 3 wires. one for just tail lights a ground and a turn/brake wire. the brake and turn signal go back on the same wire its the bikes wiring that splits the signal to either go brake or turn. i would start at the switches and work your way back from there.
Carl (Gringo39)
Carl… Welcome to Trike Talk👍👍
Hi Carl, :welcome: to Trike Talk and your first post
Run all of your fuses and relays, keep in mind just because a fuse looks good does not mean it is, we have seen many that have had fuse problems go ahead and replace them with new ones and solve their problems, good luck on troubleshooting
3WHEELR
