Need some help with stamped numbers on case
Aug 28, 2016
36
28
Fort Mill, SC
Robert
I have a type 3 case on my trike while looking at it i found the number 327 stamped in both sides at the flywheel end. What do the numbers mean? Are they from a machine shop?
Any help would be great.
I will check around
But
I always was under the impression that those numbers were there from the factory. Was to keep case halves together. Can not mix and match halves.
The numbers that identify what the engine is are on the gen stand pad.
I will check around
But
I believe you are correct Rex. I think that is all them numbers indicate.
Trike#1
