Need help with Champion trailer wiring
Aug 23, 2021
9
8
East Valley, Az.
Hello all
I need some help with getting the wiring figured out on my Champion trike kit on my 2006 VTX1800C.
The trike has 6 wires that I understand are:
Brown - running/tail
Green - right turn
Yellow - left turn
Black - ground
Red - brake
Blue - accessory (12v +)
My Trailer (that I have recently purchased) has a 5 flat connector and there IS a pair of wires INSIDE the cargo area (that I assume is for a aux battery).
The lights on the Trailer are basic tail/brake, and side running lights.
I am trying to figure out how to properly install a connector on the trike to be able to connect to the trailer's existing 5 flat connector.
I guess what is confusing me on the trike wiring is that it has separate wires for the turn signal and the brake lights.
So
I dont know what wires, should go where, on the connector that I need to install on the Trike.
Any help would be greatly appreciated.
Thank you
Ron
Trike to Trailer wiring Hookup
This is how I connected my trike to trailer with a sub harness or tapping direct.
Your trike Blue (+ hotwire) is for connecting an interior light or a cig lighter/usb charger/etc. that's always ON but will require a 6 wire flat connector.
I hope this will help you out.
LOa0jHgWX_dSfotjfjQbAD10YAmYZ9YYAFbOXEwsMPRxlcr7eK-sN-DElg_T6U6pYRss52y7kmg-_j04hzwLgVzrZahY4H3kNHH52kHc82D6J4adAtmVdZCAoU1ARZCbOH7QMSCWt73zqKN4bnCjTVIlfh3RbXACdNap8bnnOFTLgsJSlHDK0OS5RboBEo6pXqzDHTLlVNfDG46vktZ9P5ESsaZPknT-EuO-rDozp4B7hQl-Q7jfwXCcyAXn2vdUFBO-QXyJRovQytzk3YCUQ6zNl_bqLBEYqxDlN8TPHzxSjafAE8WUcCje01NLnIfohGqfpvUjNTlkg9BOALtI_ee1ptRtRwiNt3S7LHxnjqM4Gm4OC-ZM_ADqK0feQ_Le_8ObC4gt_WcpcKGAZrskME9tGFPeKZx2XuSLLM3X41afsPBuehU-GsMshqzyTGg22DrfsibNCiXEn7tp8e68IXpSg6cJFYLXoobgeZyUFbbFhiVXiI6ZJx8mGxjxwHLihGU3hOtqm5HoFMjnon0h4xiyECKXSLLxR5WuWbghqNgL1L2v_SoGQYWpHkZPZamI-HtGuFUJlFqGD2qYUMaWqD1cqxg-oghBKWT7oSTWzezmZlw4Eqp_86_XGvvBYBskIjH-09Lr6LSPraLm-tGNTplLz0EwzEuUmfWHhXnTSwES5xQEKgU2yciZ_S1f_W25_53BqCIZlXvZkAdBcbNtm3Cp4w=w596-h298-no
Tozbro
