Mechanical reverse
Oct 12, 2015
22
8
Albany
For our '15 Tri Glide I finally had a local shop put in a Motor Trike clutch operated mechanical reverse. Few times I've used it, it worked g-r-e-a-t! Only annoyance is "finding" neutral each time. Able to back up our inclined driveway which the electric reverse balked at doing. Watch it though...easy on the throttle as I about backed thru the rear wall of garage;). Maybe see you all in Sturgis this year?
I had the MotorTrike mechanical reverse installed on my Trike Glide. I like the fact if you are in a forward gear and reverse gear at the same time, the engine will shut off to prevent damage to the tranny.
Bullet Proof
