Linked Brake System Info And How It Works
Mar 5, 2015
474
366
Bakersfield, CA
Bill
I read everything in my Trike service Manuel today concerning the linked brakes. It said nothing about any special adjustments needed. It did however go into detail about a specific way the linked brake system is suppose to be bled and serviced. If this is not done correctly there could be issues or if there is a plugged or blocked bleed back valve on the front there could be braking issues. There were several symptoms mentioned which included dragging or locking brakes.
This is how the Linked Brake system functions according to the manual.
The rear brake peddle activates the middle pistons in the front brake calipers when applied along with the rear brakes. The front brake applies the rest of the pistons in the front calipers when applied. The outside line to each front caliper is from the rear brake peddle. The front brake by it self only operates the front brakes.
Ride Safe All, :)
Bill G
Ride Safe All, :)
Bill G
:Agree: You're right on the money.
QuyenDevin
