Light on after having my 2012 Goldwing triked
Aug 9, 2010
31
chester sc
Had my 2912 Goldwing triked with a Motor Trike Adventure kit and the TPMS-{tire pressure monitoring system} light stays on all the time, Anytone had this problem?I will take it back to the dealer at 1000 miles for their requested check up.
Mine is a 2012 with a csc...I was told that they had to disable the system..my light is not on but also does not work with the front tire..I was told if I wanted tpms I would have to buy a 3 wheel aftermarket system and would work independent of the trike
I have a 12 Roadsmith an my front one still works..............they need to wire it up right .............take it back to your installer............if you need help I can take the cover off an give you how to wire it...........hisst
Kickstand_Korner
