Light Bulb out?
Oct 31, 2012
41
Cabot,Arkansas
I have a bulb out on my Goldwing 1800 trike,it is behine my right frount Mirrow,I see a screw on the bottom of the Mirow frame but it seems that my mirrow will fall out, where do I change it?
Remove the pocket on the right side of the bike. If it is the high beam it is on the outside. Remove the rubber grommet and remove the bulb. DO NOT buy one a the dealer. It is twice the price than any auto parts store. You can't see the work area, you just do it by feel. Do not touch the new bulb. All 4 bulbs can be changed that way. No need to open the fairing up like some suggest. Don't take the mirror off. It is not necessary.
Remove the screw underneath the mirror housing and pull the mirror out by releasing the 2 tabs on the top inside of the housing. Carefully remove the bulb and replace. Reinstall the mirror and screw in reverse order. I read where that screw can be a real pain to thread in.
If you want to make the job easier use the screwdriver that comes in the toolkit. The screw uses a JLS screwdriver and sometimes these mirror screws have been screwed in very tight and a philips will just sometimes strip them out.
mtorcyclejoe
