LED"s
Ed H
60+ Posts
Jan 1, 2018
174
76
Milton Mills, NH
Ed
I know I have seen a thread on this but......
How does one slow the blinkers down after installing LED's? The bike is a 2016, replaced the directions with Custom Dynamics and led bulbs in the rear.
Thanks guys.
From Their Web Page
Custom Dynamics® Technical BulletinTurn Signal Sync on H-D BCM ModelsQuestions? Call us at: 1 (800) 382-1388 M-TH 8:30AM-5:30PM / FR 9:30AM-5:30PM EST07-2016TECHSome Harley-Davidson models equipped with canbus/BCM electrical systems while installing Custom Dynamics® LED turn signals in place of incandescent bulbs, will need to per-form a turn signal sync so that the product will function properly with the system.1.Turn Ignition on, but do not start the bike.2.Turn on 4 way hazards by pressing the hazard button on the controls. Turn Signal Sync Procedure3.Turn the Ignition off letting hazards run. IF the bike has security they will flash 5 or 6 times and then pause. This is normal. They will go back to flashing normal hazard mode.4.Let hazards run 1-2 minutes.5.Turn Ignition back on.6.Turn off hazards.7.Turn Ignition off and then back on.8.Check function of both turn signals.Note: Follow the instruction above. DO NOT press both turn signal switch's at the same time. That is the way the hazards activate on PRECANBUS bikes.
  • Like
Reactions: MDO
Get a blinker that works off a timer rather than off of a load. There are many brands made for led applications. Mine was about $12 from eBay.
From Their Web Page
Thank you, I will try that, if no success I will look for a flasher.
ledgin
