Key FOB...
Sully
Trike Talk Executive Chef
Gold Member
Mar 23, 2014
27,930
59,733
Kennesaw, GA
Jerry
When your battery goes Dead, do you lose the codes and info in you FOB ??? Will everything be normal when you replace the dead battery ????
Change the battery once a year your Fob will be good to go
Every once in a while you will see some have reported even after changing the battery the Fob does not work
If this happens simply pry up on the battery contact, this has helped many
Also use a good brand battery, not the Bo Bo ones from the dollar stores
Also have been this route, lol. Now I change the batteries once a year on the bikes anniversary, nothing gets lost.
Remembering to change the fob battery on a certain date is too much for me. I carry a spare battery along with the owners manual.
Same here......But no manual....Just the Securely card with the (My) code numbers.......
And just FYI....Most if not all codes come to the dealers from the factory with all number 1's....
Similar threads
El Cabron
