JACKIE
Welcome glad you joined us. Don't know if they make for your bike,but Superbrace is a sponsor here. Give them a try. RIDE SAFE
Hi purchased recently a suzuki 1500 c90 lehman jackel 2007 need steering stabelizor kit at a reasonable price and instructions steering wabbeling at low speeds;)
Jackie,
The low-speed wobble could also be tires. Check rear pressure at 20-22psi, front pressure 35-38psi, check rear shocks spring preload and check for abnormal wear on the front tire.
The C-90 Lehman Jackal originally came with a stabilizer factory installed. It must have been removed previously. I may have them in stock and will check this morning.
jackie,
the low-speed wobble could also be tires. Check rear pressure at 20-22psi, front pressure 35-38psi, check rear shocks spring preload and check for abnormal wear on the front tire.
The c-90 lehman jackal originally came with a stabilizer factory installed. It must have been removed previously. I may have them in stock and will check this morning.
hi lee thanks so much for the feedback will be waiting for your responce
i have 20lbs in rear tires 25lbs on f/tire ill have f/tire checked only 15k miles on trike
jackie
Jackie,
HI lee call me 631 559 1949 JACKIE
I TOOK PHOTOES
I CAN EMAIL THEM TO YOU GIVE ME YOUR PHONE NUMBER AND EMAIL ADDRESS
JACKIE
snowking1979
