J&S Jack Question need some help
bowelder
80+ Posts
Apr 16, 2016
86
40
Little Egg Harbor, NJ
Bob
I have a J&S jack that I bought new a few years ago that I got for my 2016 Tri Glide it was the latter model that also worked with the M-8's. I now have a 2022 Tri-glide and it'll lift it But I can't change the engine oil because the lifting pad is in the way.The plug is right over the lifting pad. I can't position it any farther forward because the crossover pipe hits the other pad. Those of you that have a J&S jack and a M-8 trike have you also run into this problem and if so how did you fix it or did you have to live with the problem? I'm back to laying on the floor to change the oil.
jhlesher
