installing new cam
Mar 2, 2018
39
26
Vale, NC
Gabe
hi installing new cam 2018 triglide having a problem getting motor to turn wheels up off ground in 6th gear plugs out
my first time with trike done 2 wheels before i know its something to do with rear
thanks for help
gabe
thanks for help
gabe
I put a socket on the crank gear, 1/2 driver, slowly turn motor over that way. Save a lot of problems.
Push Rods?
Just curious, when most of you change out cams do you pull the push rods out from the top or cut them? When I put Wood 555 cams in my 07 Road Glide, I cut them and used SE adjustable push rods. Saved me some time and I have never had any problems with them. I did use some nuts that somebody (can't remember who) was making that were supposed to be better than the supplied SE nuts. Or course I wouldn't do this on a high power build.
you can cut them out but i went with fueling push rods so i took mine out from the top i think a adjustable push rod on the m8 motor is going to flex
you have 2 spring you are pushing on now
just me
I always cut mine. Installing the SE adjustable is easy.
2011Spyder*
