On today’s ride I received an error message indicating the incorrect key had been inserted in the ignition. This is related to the DESS system. It was raining and my phone was near the key. I removed the key and the error went away. I understand that this can be a normal error code, but it raises the question how do you check the error codes on the Spyder? (The Spyder is new with under 600 miles. This is the first and only time that I have seen this error)
Other points unrelated to the subject heading - I installed the latest update. It does help with the Apple CarPlay connection, but there are still issues. On today’s ride, the unit dropped from one Cardo headset then the other. When using voice commands, the audio dropped but the display still showed the active song.
The time changed - I changed the time using the menu but there was no way to change the date. Is this automatic?
As always, thank you for your help
Stay safe
Stay safe
