HD Hidden Antenna
Mar 27, 2017
58
33
Little Elm
Does anyone have any experience with the HD Internal antenna?
Wanted to remove the two antennas from the tour-pak . . .
Thank you
Uncledoc
Thank you
Uncledoc
Other than the obvious cosmetic gain....I've never heard of anyone happy with the reception of the Internal Antenna.
I just ordered a "shorty" antenna from Amazon to see how it works (and cover a dumb mistake.) 25 bucks, I figure worst case it will protect the threads.
I went with the hidden antenna because I hated the one sticking up in the back. 2014 does not have a CB so only one shorty. I listen to my music on my iPhone if I listen to any so long distance reception was not a concern.
Those whips were a pain in the ass, always in our face, in the way, etc. I got some shortys, still in the way.
When I changed handlebars, I routed the new clutch cable wrong where it goes by the radio, inside the fairing. Broke the plug end on the antenna cable, couldn't find just the plug end, no Radio Shacks any more...
Rerouted the clutch cable, and since I needed to get a new antenna, I got the hidden unit from H-D, it was cheaper than the whip antenna. We're in Seattle so reception is fine. I don't know if the Kuryakyn one is any better or worse.
If you're in the middle of nowhere, no antenna will work, that's when you plug in your phone for tunes...
Looks a lot better in my opinion without those whips, and the overnight cover is way easier to put on!
Does anyone have any experience with the HD Internal antenna?Wanted to remove the two antennas from the tour-pak . . Thank you Uncledoc
Tried the HD internal antenna and lost quite a bit on the CB...the AM/FM no real problem. Pulled the HD unit out and put in a Dakota Digital AM/FM internal antenna I had laying on the shelf in. CB now operating off the external antenna again. Only reason I put the digital in is I'm still thinking about pulling my tour-pack off for around town and don't use the CB in town so wouldn't have a need for that particular antenna.
8~\o
craneop63
