Further research on rear/reverse front tire for Valkyrie 1500
DPK
Nov 9, 2014
102
19
Little Rock, AR
DK
I'm replacing my front tire on my Valk 1500. I intend to purchase the Michilen Pilot Active and reverse-mount it.
This is my second thread dealing with this after narrowing down possibilities.
Two questions:
1) Would the sidewall on a V rated tire be stiffer than
H rated tire?
2) There seems to be two sizes being used by forum
members:
150/90/17V
150/70/17H or V
The 90 series tire in a MPA is available only as a V rated tire while the 70 series comes in either H or V ratings.
Apparently the 90 series introduces less speedometer error and is the tire I prefer absent clearance or rating problems.
Any my suggestions or comments regarding the above would be appreciated.
Dan
This is my second thread dealing with this after narrowing down possibilities. Only one possibility.... sorry!!!
Two questions:
1) Would the sidewall on a V rated tire be stiffer than H rated tire?
2) There seems to be two sizes being used by forum members:
NOPE !!
150/90/17V & 150 / 70 / 17 with a 69V Load Index H or V
Dan
Dan,
Michelin Pilot Activ only make one size that fit your bike /
MICHELIN Pilot Activ
Premium-quality bias-ply replacement tire
Zoom
PICTURES
  • Description
  • Sizes
  • More
FRONT
WidthHeightTypeDiameterM/C(Load / Speed Index)Inner TubeLetter
10090-18M/C56 VTL/TT
10090-19M/C57 VTL/TT
11080-17M/C57 VTL/TT
11080-18M/C58 VTL/TT
11090-18M/C61 VTL/TT
12070-17M/C58 VTL/TT
12080-16M/C60 VTL/TT
3.250-1954 HTL/TT
9090-18M/C51 HTL/TT
REAR
12090-18M/C65 VTL/TT
13070-18M/C63 HTL/TT
13080-17M/C65 HTL/TT
13080-18M/C66 VTL/TT
13090-17M/C68 VTL/TT
14080-17M/C69 VTL/TT
15070-17M/C69 VTL/TT$121.99
4.000-1864 HTL/TT
They do not make a 150 / 90 / 17 size tire in the Michelin Pilot Activ / The above is direct from Michelin http://motorcycle.michelinman.com/tires/michelin-pilot-activ#dim not sure where your looking that size up but for Pilot Activ its not listed.....
Are their other tires in 150 / 90 / 17 size , Find tires by size : http://www.motorcycle-superstore.com/tires?wt.ac=tires_mngr_-_sub_1_11.05.15_tirefinder 0 - Comes Up there are a few 80 Aspect tires but none I would run on the Valk.... Sorry only 1 Good Choice the MPA in 150 / 70 / 17 and it is a rear sport bike tire which many run on the front and it is a Bias Ply tire so it has a strong sidewall / bike & Trike tires have never really worried about the sidewall as the weight factor is not like a car or truck tire. I run the MPA tire on my Goldwing and have for the past three tires at about 25,000 miles and highly recommend it.
FlintM
