GoldWingrGreg
JustWings.com
This is most important when pulling a trailer with a m/c.
Basically there are 2 types of m/c trailers out there. Small ones intended to be towed by a car, but, because of their small size, are marketed to the m/c community, and m/c specific tow behind trailers. The m/c specific tow behind trailers have 3 district features making them much more safe to use.
- a full swivel hitch that allows the trailer to flip without flipping the m/c too
- independent suspension with a sway bar. This helps keep the trailer tires on the ground and less likely to flip.
- an upward bend in the hitch bar. It helps keep the motorcycle's rear tire on the ground while braking in a curve. Having a straight bar can be scary when coming into a curve to fast, having to brake, and dealing with a rear tire wanting to lift off the pavement.
Below are examples of trailers that do not have all 3.
