Front Forks Stiff
Apr 25, 2019
54
21
Fort Myers, FL
Mark
I just bought an ’03 GL1800 with a Champion kit. The front suspension feels like it is welded solid. Every little imperfection in the road comes right up the handlebars. When I stand on the pegs and “pounce” or “lunge” on the handlebars to try to bake the front-end bounce, there is not one bit of give to the forks. However, if the trike is slowly rolling forward and I slam the front brake, the front-end dives like expected.
Being new to the trike world, is this normal? I’ve always heard that riding a Goldwing is like riding a couch, but not in this case. What weight oil should be in the front forks? I’m tempted to change it out for a lighter oil.
:welcome: To the Trike Talk Family! FROM SOUTH
attachment.php
Angleton, TX
Howdy Mark :wave4:
:wave4:
Check with installer or previous owner. Sounds like progressive springs may have been installed in forks. Also check air pressure in front tire. 38 to 40 psi might help. :wave4:
Do you know the following:
1. Does the ADV work or is it stuck?
2. Stock fork springs or something like progressives?
3. How many miles since the forks were serviced, if at all? Might need a total rebuild using new OEM springs.
4. What Pressure do you have in the front tire? I would not run more than 36psi
Just because it has a rake kit(if it does)that will not make the suspension "rock hard"
Puzzled by "front suspension feels like it is welded solid" but, then you say "if the trike is slowly rolling forward and I slam the front brake, the front-end dives like expected."
TPost
