Fork Air Pressure
Jun 4, 2014
234
49
Delray Beach, FL
Hocky
What effect does no pressure in forks of Goldwing 1500 have? How important is it to have pressure in the forks? 4.5 degree rake on 95' Wing w/Hannigan Conversion
Thanks, Hocky :Dorag:
Helps to keep the forks from compressing when coming to a stop, under hard braking.
Also good for suspension to have air in the forks.
Don't forget about changing the fork oil, periodically
Be very careful adding air. Do NOT use a compressor use a hand pump. About 4 or 5 lb is enough. I have none in mine. You could blue your seals if you add to much pressure
I had a 1500 and shortly after delivery my dealer recommended removing the air pressure system and installing gl 1200 fork springs which were stronger. It worked well. And no more carrying a pump and dealing with pressure changes caused by temperature fluctuation.
Another bike I had, the CB 900 custom also had air assist and the forks were plagued with "sticking"; they would not move smoothly through the normal movement. Changed it out to heavier springs and problem solved.
YMMV :)
i keep about 5-6 with stock springs, if u have the progressive springs many suggest no air . & yes small air pump, u can go as high as 10-12 but u don't notice a difference or i don't so i just stay around 5-6.
John_C
