FL light
Light came on yesterday after 100 hundred miles, no difference in power or the way trike was running, 20miles more stopped 2hours! started trike light went off, came back on after30 miles, stopped shut off engine to put on jackets, restarted engine no light 80 miles to the house no light! Could it be a bad sensor, dirty air filter, or is this normal before the fuel system shuts down?2003honda goldwing 1800! butch
FL codes
Found side stand switch turned it so the light went out then flashed 1 long 5short so15is the right code now trying to find what this one is.if anyone has code I would appreciate it!ed
#4 injector
Going to try sea foam but will check wiring for loose connection or broken wire.Now have a really Stupid question, setting on the bike which side and going from front to back where is the#4injector located??ed
Dragon warrior
