First coolant change
rhino65
250+ Posts
Aug 14, 2016
263
49
Atwood, IL
Brian
Did my first coolant change today. Removed the tank underneath as well and emptied it. After refilling the tank to lower level I reinstalled tank not spilling any. When I checked level I couldn't get any on stick. Added till it was a bit below halfway mark on stick. Is this normal?
I do not remember exactly where the coolant came up to but I do remember adding some additional. I no longer remove the tank when doing coolant changes.
Just a suggestion. Instead of removing the overflow tank just use a MityVac type pump and pump out coolant. Harbor Freight sells their version on sale for around $10.00. It saves quit a bit of time and effort.
+3 on using the Mitey Vac for pumping out the overflow reservoir.
I use 4 quarts on a change. After draining and reinstalling the drain bolt/washer, I try to slowly trickle in as much coolant as I can. The trick here is to go real slow until it's full. Then crank the bike and give 2-3 good blurps of the throttle and immediately shut it down. Trickle in some more, then blurp it again. I do this several times till it just won't take any more. That will get something over 3 quarts in there. The remainder is then added to the overflow tank. I then run the bike thru a couple of heat/cool cycles and check the level in the overflow tank. Usually, it's about half way if all is well.
Sometimes, I've had to add a little. Most of the time, it's pretty much half way. BTW, that copper washer on the drain bolt: There is no torque spec that I have ever found for it...and Honda gets a little over $2 for its replacement. Holding it with needle nose pliers, I will heat it with a propane torch till it just starts glowing red. This anneals it a little bit and then I re-use it after it cools off. Once I do this to the washer, it is replaced the next time the coolant is drained. Basically, I replace it every other coolant change with this approach. Been doing this for a long time and haven't had an issue with any drain bolt leakage.
Hope this helps.
LJ
Ron A
