Electric Gremlins GL1800
Jun 4, 2014
234
49
Delray Beach, FL
Hocky
Yep those buggers are the worst! 2003/2004 GW 1800, Roadsmith.
Bike is in a no start condition with no power at all when the ign key is turned on. Lots of batter voltage.
Reading 3-4 volts when checking any metal on the bike from positive batt term to metal. Post to post is normal @ 12.7V.
I've lost confidence in the bike. This is my 4th GW & have taken lots of interstate trips on my 1500's with confidence so this is a real bummer!
Any suggestions would be appreciated.
Thx, Hocky
Electric Gremlins (from incorrect forum)
Thx MDO for the suggested move to the correct Forum!
Thx, Hocky
Thx, Hocky
I agree that it sounds like a grounding problem. From the frame to the positive terminal on the battery should read battery full voltage. If you're only reading 3-4 volts I am suspect that your grounding lug has a really corroded connection or the wire from the negative battery terminal has somehow been damaged. It might also be that the main system fuse is bad/corroded.
You might also check voltage from battery negative terminal to the hot side of a fuse in your fuse box to see if full voltage is there. Key will have to be 'On".
craneop63
