Dynabeads?
May 23, 2013
201
38
Mackinaw, IL
Howard
I have Dyna beads in my front and when going 30 mph I here the tire singing. do you think it could be the beads? 33 or 27 mph it stops.
I have run dynabeads for thousands of miles and have had no problems. I don't think your problem is the beads, how is your tire pressure?
I have about 8,000 on my front tire (BT-45 with beads). I have no issues like you describe and I would not suspect the beads being the problem. I'd be inclined to go with tire wear and/or tread pattern as the culprit. When you figure it out, let us know. Good luck... ThumbUp
I have a Michelin Pilot activ rear tire mounted backwards with about 5000 miles on it. The noise just started no cupping at all and I have a superbrace on, do you think it could be the brace?
[h=3][/h]
Its the tread pattern. Ive had 2 of them and they like to sing between 25-35 mph. Just make sure you keep that tire pressure around 41 psi for best wear.
John_C
