DK's convertible lift
Trampas
1000+ Posts
Aug 27, 2016
1,075
589
Des Moines, IA
James
A friend of mine on my suggestion contacted DK Products about the trike lift. He got the convertible lift and we installed it on his 2012 trike today. Everything went well, basically dealers told him he couldn't have a lift because of his exhaust, not sure what that is about since the exhaust didn't play into it putting it on, guess the dealer didn't want to do it, not enough time on the clock to pay the mechanic.
Anyway it is on, he could have went with a regular lift from DK instead of the convertible one, plenty of room for a regular one, my point is on the convertible one with the 4 holes, look at the picture on the directions, it shows for full lift or the second holes if full lift doesn't work. We ended up putting it in the first hole and the third hole, which amount to 1/4" less of lift, the second hole and fourth hole for a full lift. Look at the picture to determine what you want, I had my side in 2nd and 4th hole and he had his in 1st and 3rd, so I changed mine to be like his since it was his bike, we didn't look at the picture very good, LOL, but everything went together just fine.
I'm sure he will be happy with it since he was running 50lbs of air and still bottoming out sometimes when riding, I'm sure he will experiment with the air and tire pressure to get the best ride.
All for now Trampas
Sounds like you had a lot of fun Trampas..Lol on the 2016 and older model Trikes most times you can install the 1 1/4" without any issues.
All I got to add is for the 2017 model trikes the 1/4" less lift option is a must. The clearance between the swing arm and the weld on the exhaust (weld on header S bend) is to close. The swing arm either hits on the swing arm or has about 1/16" clearance with the 2017 model trikes on the ground.
With the 1/4" less lift on the 2017 model Trikes there is no clearance issues. Seems this issue has been played way down or not known out there concerning the 2017 models. More and more here locally are starting to find out though when they try to add the regular or standard 1 1/4" lifts that have been available for Trikes. I found out the hard way myself on this issue with our 2017.
It's a good thing DK Customs has addressed this issue. Also other lift manufacture are starting to do the same concerning 2017 model trikes.
Ride Safe All, :)
Bill G
Click HERE to see photo's and more details on the Convertible Comfort Lift™ Kit.
Trampas explained it well...it is Two Comfort Lifts™ Built into One....allowing you to have the best of all worlds without having to compromise/decide prior to ordering which one to get.
BikerBobs2
