Dk customs. Question
520fd
550+ Posts
Gold Member
Aug 9, 2010
499
388
Davenport, IA
Jerry
Kevin. I want to buy one of your Convertible Comfort lift kits. Sometime during the winter, I would like to get a set of 14" Pro-Action Shocks. What I'm asking I guess, is will the Convertible Comfort lift (standard air shock) Fit the 14" shocks when I get ready to install them? Or would I have to order 14" specific Lift? Thanks Jerry
As you noted, there are two Convertible Comfort Lift™ Kits.
1 for the standard length 13" shocks
1 for the 14" Trike Series Shocks
The Convertible Comfort Lift™ for the 13" shocks (factory) CANNOT be used with the 14" shocks.
The Comfort Lift Kit™ for the 14" TS Shocks WILL work with your 13" factory shocks, it will not give the maximum lift, but you will not need to buy & swap our Lift brackets when you do upgrade your shocks to the 14" ones.
LINK
LINK
Thanks Kevin. I was hoping that not be the case, but had a feeling that would be the answer. Have to rethink my money situation and figure something out. Thanks again.
Wow, I was just wondering the same think about the convertible lift kits. So Kevin how much lift will the kit for the 14" shocks give when installed using the oie 13" shocks . . . and to compare that how much with the kit designed for the 13" shocks give with the oem 13" shocks. Thanks!
When using the 14" Lift Kit on the 13" shocks, it will give about .5" lift at the rear of the Trike.
When using the 13" Lift Kit on the 13" shocks, it will give about 1.6" lift at the rear of the Trike.
If you are not planning on getting the 14" shocks anytime soon, you may be happier getting the lift kit for the 13" shocks to use with the 13" shocks.
Using the 14" lift kit with the 13" shocks will give you some of the benefit....But Not all of it....it would just be an interim benefit until you got the 14" shocks.
Thanks. Exactly the info I needed!
dhinzman1
