**DK CUSTOM - Pro-Action Street Series Shocks**
Jun 15, 2013
9,366
9,785
Red Banks, MS
DK CUSTOM PRODUCTS
MADE IN THE USA!
CUSTOM DESIGNED & DEVELOPED SHOCKS
For
Harley-Davidson
Sportster ~ Dyna ~ Touring ~ Trike
Go HERE for a full report on our rear suspension testing!
The T6061 Billet aluminum bodies house a unique 3-stage progressive valving system for compression, and a 2 stage rebound system. Coupled with "fit to you" coil over springs that have an adjustable pre-load, you will be amazed how much smoother and more stable your bike/trike will ride.
These Street Series Shocks are available in 3 lengths: 11.25", 12.25" & 13.25".
The travel is 2.5", 3" & 3.5" respectively. Combined with less sag than the stock shocks, this gives an average of 33% - 50% MORE Travel. (Unless otherwise requested, we will send the OEM length shocks for your bike to you)
When you order you will be asked some easy questions. Your answers give us the information needed to use the correct spring rate for your shocks, as well as giving us the info needed to adjust the pre-load and rebound for you. This way when you receive the shocks they are already set-up for you. Simply bolt them on and ride!
You can Lower or Increase the Height of your Bike by requesting a different Length Shock. We will send the stock height shocks for your bike, unless you request in the "Special Instructions", at checkout, 1" shorter or 1" taller Shocks.
Go HERE for more photos and full details!
Cristy
GWearsch
