***DK Custom-Introducing FINNED HANDLEBAR CLAMPS-Save 10%***
Jun 15, 2013
9,404
9,944
Red Banks, MS
Introducing
Timeless Classic Design
INTRODUCTORY SPECIAL
Save 10%
Your Finish Choice of:
Sano Black
Contrast Cut
Machine Cut
  • Fits All Sportster Models except the Forty-Eight.
      • Also fits most Dyna, some Softail Models, and any other motorcycle where the handlebar clamps mount to the top tree via a 1/2" bolt through the bottom of the tree.
          • Designed to take the place of the OEM handlebar clamp.
              • Great option for replacing the OEM handlebar clamp when doing a Speedometer/Indicator Lights Relocation.
                  • No cables or wires need to be changed to install these Handlebar Clamps with the factory bars.
                      • These should Not be used with apes that are taller than 12". They can be used with 12" apes with Riser Extensions. But for taller ape-hanger bars, because of the leverage on the bars, you want to use a one piece top clamp.
          SAVE 10%!
Go HERE for more photos and details!
Use Coupon Code: Save-10
At Checkout
www.DKCustomProducts.com
Voice 662-252-8828
Text 662-420-4891
10% Savings Code expires October 2, 2018
Contrast Cut Handlebar Clamps
These TWO-PIECE Classic Design Handlebar Clamps Give Your Bike a Different Look than all the other Bikes Running Around with the one-piece clamshell handlebar clamps.
Sometimes it's the Little Things that Make The Difference!
Go HERE to see more photos and details!
Save 10% Now!
At Checkout!
Machined Billet Handlebar Clamps
CNC Machined, by DK Custom Products, from 6061 Billet Aluminum.
These have a Machine Cut Aluminum Finish that can be polished to a mirror finish.
Save 10% now using coupon code Save-10 at checkout!
Black Handlebar Clamps
If you're wanting a taller look, needing more clearance, or wanting more comfort in the shoulders and back, these work great with the Riser Extensions!
Save 10% on these and ALL Riser Extensions at checkout!
See these and all riser extensions HERE!
***Order NOW! Code expires tomorrow(10/2/18) at midnight!***
tony29
