Jack Klarich
Gold Member
Get Into DTC Viewing Mode:
Viewing and clearing DTC's: (Clear codes at your own risk)(Make sure you know what you are doing or consult a Harley mechanic)
- Make sure the ignition and Boom Box have been off for at least 15 seconds
- Press & hold the power/mute button on the Boom Box
- While holding the power/mute button in, turn ignition to accessory position
- Keep holding the power/mute button down
- Wait until the Boom Box boots up
- Wait for the Boom Box main warning screen to appear
- Hold and additional 2 seconds
- Press the “accept” button to enter the Boom Box back-end
- Select the “DTC” button on the Boom Box screen to enter DTC mode
- If not DTC codes it will immediately say “No logged DTCs” and you are done
- If there are DTC's it will list them
- Select each one using the touch screen or your right joy stick/toggle on your right control cluster to cycle through the process
- To exit the DTC and back-end of the Boom Box system just turn the ignition to the off position
