I use my Sears Yellow Jack just to raise the front to do the front wheel. Works for that.
Hi Guys Just traded my 07 Electra Glide for a 2012 Tri Glide. Do I need to trade in my Craftsman Jack for a new one to lift the Tri Glide or is it possible to use it? Mostly used for getting off the ground a couple inches to clean wheels. Thanks, Bill
The J&S jack lifts front on the frame and rear on the swing arm under the pivot point. You can make an adapter to make your old jack work if it can lift the 1250 pounds. (Thanks to the poster whose pic I "borrowed"!)
That being said J&S has modified their jack to work with the 2017's different exhaust.
I have a 2014 and my J&S jack is awesome. I have a conversion rail from them so it will also work like a standard lift on non-triglides.
Boborag:
I wish they offered an adaptor to put on the 2 wheel style jack to convert to the trike.![]()
Their 2 wheel jack was not designed to lift the weight of a TriGlide .... and that is why they never offered an adapter kit.
Boborag:
Check the pit-bull web site bet their adpter would work. They just make one jack and have adpter for the trike that is what I have.I wish they offered an adaptor to put on the 2 wheel style jack to convert to the trike.![]()
Just saw this J&S 2014 trike jack on the HD Forum. 300.00
https://www.hdforums.com/forum/trik...185577-j-and-s-trike-floor-lift-michigan.html
Jim
Just looked on HDFORUM. Now there saying that the J&S trike jack Won't work on the 2017 TriGlides. Say's the crossover is in the way.
J&S, You got some splaining to do.
520fd, the J&S TRIKE JACKS that were made before late 2016 were made with the "extended arm" on the LEFT hand side of the jack if you were standing behind the jack, and you used it from the RIGHT hand side of the trike. With the introduction of the 2017 bikes with the M8 engine there was just enough difference in the area around the crossover that J&S had to make some changes to the jacks for the 2017 and up models. Part of this change required them to move the "extended arm" to the RIGHT hand side of the jack and you use it from the LEFT hand side of the trike. When I ordered my Trike air model back last November/December I had to wait about a month or so before it shipped because they were just getting all the new parts designed, built and painted. However, it is my understanding that they make a kit for the older TRIKE jacks to move the arm to the RIGHT side and it will work on the newer model trikes. Also, there was several people in the forums that reported they were actually able to get their older model to work but they had to be very careful when lining it up under the trike. If you are buying a "used" J&S trike jack you want to make sure it is one of the newer models or you will probably have to buy the conversion if you plan on using it on a 2017 and up. The people at J&S will be glad to explain all of this to you and help you. I have owned two of their jacks over the years and they are good people to work with. BTW, they also make an adapter kit that you can install in about 5 minutes to use the trike jack on regular 2 wheel model HD bikes. As I said, talk to J&S. I do not profess to be an expert on J&S jacks, and I have been wrong a few times in my life, but my wife doesn't know that.Hope this helps.
