Doug D.
"Tin Man"
Ok… What additives, if any, are you guys using to counteract the effects of ethanol in gasoline??
Corn gas is about all that’s available around here locally, and it makes my trike run like total crap. I was out riding last weekend, and by shear luck, I stopped at a Conoco station in Loose Creek, MO to top off. They just happened to have non-ethanol 91 octane fuel. I took on about 4 gals on top of the 2.5 of 91 oct corn gas that was already in the tank, and the difference in the way the trike ran was un-friggin’-believable! Damn thing ran like a scalded cat!
So, if anybody has found an additive that makes a significant difference in performance when running ethanol contaminated gas, I’d sure like to know what it is.
Or, if anyone has made any engine mods that seemed to help, please share those too! I’m running a 1600cc dual port with an Engle 110 cam (pre-Chinese), stock 34 PICT/3 carb and a dual advance dizzy. Everything else is stock. Thinking about a Weber 32/36 2 bbl and a Bosch 009 dizzy…
