keikat2
90+ Posts
Cloudy Hydraulic Clutch Fluid Explained By Dealer After Flush
Went to the local Harley dealership yesterday to have my Brake/Clutch hydraulic fluid flushed. A few days before, when I scheduled the appointment, the service manager gave me an initial quote of $290.00 to flush the Brake/Clutch systems. After I checked my Trike into the dealership, about one and half hours had passed before the service manager came into the service lounge and informed me the aftermarket downpipes and trunk body were going to have to be removed to get to the clutch bleeder valve. Also, he advised me there was going to be an additional $507.00 labor charge (three and one half hours) to remove and reinstall the downpipes and trunk body making the total service cost now $797.00. After further discussion, I asked the service manager was the unexpected $507.00 labor cost negotiable and he informed me he would discuss the additional labor cost with the service technician. In turn, I told him to go ahead and perform the clutch fluid flush since I did not want to have to perform the task of removing the trunk body myself to perform the Clutch fluid flush plus I did not know where the clutch bleeder valve was located on the Trike. Another one and half hours passed and the service manager came back into the lounge and told me my Trike was ready. Additionally, he advised the service technician and himself had discussed the additional labor cost and both agreed to lower the labor cost to $362.50 (two and one half hours). So, the final cost to perform the Brake/Clutch fluid flush wound up being $667.50 (four and half hours labor cost plus $15.00 for the DOT 4 hydraulic fluid) plus tax. After I got back home, I found a You Tube video providing instructions on how to perform a Clutch fluid flush on a two wheel Harley and determined there was no way the Trike's trunk should have had to be removed to get to the clutch bleeder valve unless there was something different about the Tri Glide. Later, I decided to remove the clutch reservoir cover to look at the new fresh hydraulic fluid. After removing the cover, my smile quickly changed to a frown due to the new clutch hydraulic fluid looking cloudy and dark at the bottom of the reservoir. So, this morning, I returned to the Harley dealership for an explanation as to why the new clutch fluid was not clear and "clean-looking" as the new brake hydraulic fluid? The service manager told me to go into the service lounge, get a cup of coffee, and he would talk with the service technician to find out why the new clutch fluid appeared cloudy and dark. After about thirty minutes, I went back into the service area and was informed by the service manager that the Harley hydraulic clutch system, when new, contains a "graphite looking" fluid/substance and that some of this substance had "bleed-back" into the new clutch reservoir fluid. Additionally, he told me there was nothing to worry about since this "bleed-back" fluid/substance would not harm the hydraulic fluid and/or clutch system. For those of you who know more about the Tri Glide hydraulic Brake/Clutch fluid flush, does the aforementioned make sense to you? This is why I hate to take my Trike into a Harley dealership to have it worked on. Thanks, Allen S.
