I already have a copy of the Champion solid axle install guide but sent the following questions to Champion this AM. Looking forward to any tips from Champion owners on these questions!
1. If I buy a traiiler hitch, can it be installed without removing the body
2. Where are the rear jack points for removing rear tires?
3. How do you check the fluid in the differential? How is oil drained from differential?
4. How often should differential oil be changed and what weight oil was used?
5. What type brake pads are used in the rear? Manufacturer and P/N? What is the minimum thickness?
6. How is the driveshaft serviced and at what intervals?
Thanks in advance! Loving the new trike! wg
