cb radio noise
Status
Not open for further replies.
Usually this is caused by the alternator. There should have been at least 3 extra pigtails that plug into various parts of the wire harness to eliminate the noise. These devices are called chokes. I have seen several bikes that for some reason they weren't installed. I believe they are available from Electrical Connection if they aren't there. You should have had an installation manual which will show you where they are installed. If you don't find that let me know and I can give you a source for the info.
Yep the filters should of come with the cb.got mine from Hal a few years ago and have no problem with noise...good luck:)
Status
Dan2003
