I have an aftermarket stainless steel headpipe. Back when I got mine ceramic coating was not an option. So I had a local coater do it. Applied both inside and out. Before I had the coated headpipe, I couldn't ride my triglide if it was over 80 deg. So far, I've ridden it for a week in the high 80s. HUGE DIFFERENCE for the better. It's still hot, but not any hotter than my '03 SE Road King.
I got tired of the heat from the exhaust. Took pipe off, sawed in half, removed catalytic converter, welded back together, installed Big Sucker A/C, V&H slip ons, Downloaded with TTS. Runs cooler and better.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
