Adjustable push rods
If you go Adjustable s you wont have to take the top end apart, it will always be a time saver PLUS you will get a better adjustment on the valves
You are replacing lifters too?
What’s the majority opinion of adjustable push rods. Getting ready to put a torque cam and upgraded oil pump in a 2018 .
Depends on the base circle of the cam. If it's the same as stock, you have the option to use the stock pushrods.
If it's different, you must use adjustable pushrods.
My preference is S&S quickie pushrods in all my modifications.
No need to remove the heads for installation. Just cut the old pushrods out.
I have used Screaming Eagle Premium adj pushrods in every engine that I have put cams in and have never had a failure. So its all about personal choice, If you are doing the work yourself then use what ever you feel will work, if you are having the work done by a shop then use what they suggest.
dhinzman1
