97 csc in gl1500, where is air outlet
Feb 10, 2013
5
sacramento, calif
I just picked up a 95 gl, it was converted in 97 with the vex solid axle, where is most likely place they put the schrader valve for the air outlet
It came with a bushtec gensis trailer, I needed to air up flat tires on trailer. Previous owners had no idea. I gave up and pulled empty trailer half mile for air.
I also just learned I need to put air in trailer system to make tires look straight up and down.
What should I be looking for as I service this trike.
Thanks ray in sac
I have a '97 1500 converted in 2011.Found mine under the seat and re-routed it down to behind right side cover.
You might check with Bushtec.I believe to air the trailer shocks requires a low pressure hand pump.
Thanks, it dawned on me to look under seat just a few minutes ago
There is a small hand pump in trailer, I think that is for shocks. I tried that for tires, gave up in 30 seconds
Looks like I have some learning to do.
Ray,
You have come to the right place to learn. There is so much knowledge and experience on here that all you need do is ask. I had a professor that once told me the only dumb question is the one you don't ask because if you are wondering about it then so are lots of others. So, ask away and gain the knowledge.ThumbUp
Kickstand_Korner
