4 way flashers
Jan 20, 2012
28
oakdale connecticut
hi i have an 05 gw 1800 trike the 4 way flashers will not go off i can not find where it is i took the front fairing off and can not find it it is not under the seat i look there too,i check the switch and it look good any help would be great thanks.:confused:
1) I think you have a stuck or bad hazard switch. Left fairing.
or
2) You have a hazard switch diode gone bad located under the seat.
My first guess is the switch has gone bad or is stuck. Look at the post found here for help on repairing the switch.
Sticky Hazard Switch Lots of information here. Hope this helps. Greg
My flasher botton was stuck so I put some electronic spray cleaner from Radio Shack on it and the next day I took my plyers and lightly pulled in different directions then I
pushed with my finger and it came lose.
FlintM
